Double Retaining Wall System
thread507-193368: Parallel Retaining Walls
It has been suggested that a temporary sheet pile wall is installed close in front of a permanent mass concrete wall. The sheet pile wall is to be tied back to the mass concrete wall at two locations and the space in between the two then back-filled. I am having difficulty finding any references for the behaviour of the filled soil between the two structures. I saw a similar thread (referenced above) but links to the information are no longer available and I was just wondering if anyone could provide new links to this type of situation.
The mass concrete wall is already designed and I am involved in checking its capability to resist the anchor forces due to installation of the sheet pile wall.
Will the filled soil between the structures behave like a silo? Is it possible that passive resistance to one wall and active pressure on the other wall will occur? Is it over conservative to assume that the pressures cancel out and therefore ignore them when checking the capability of the mass concrete wall to resist the anchor forces? Is this just an impractical system?
http://s12.postimg.org/nyp9rxrv1/Double_Retaining_...
RE: Double Retaining Wall System
BA
http://www.eng-tips.com/viewthread.cfm?qid=280817
http://www.publications.usace.army.mil/Portals/76/...
