Opening STL file as part file (as solid body)
Trying to open STL files as solid body parts but getting the warning about the part
having too many surfaces and it should be opened as a graphics body. I need it to
be a solid body. Anyone know of any work arounds, tricks or otherwise to get the part
to open as a solid body? Short of going back to client to ask to resend native part file.....
Seems like this happens too often.
RE: Opening STL file as part file (as solid body)
Are you familiar with stl files?
Stl files are coarsely faceted planar surfaces - generally of little use other than for reference in an MCAD software.
problems for the file to be opened as a solid body and one is left with the alternative to open
the file as a graphics body, which can't be used for very much. Thus my question if anyone knows
of any work arounds. Thanks for the interest.
If you are trying to use the file in SWX then you would be so much better off asking for the file in one the following formats (in order of preference): 1. SolidWorks part file, 2. Parasolid, 3. ACIS, 4. STEP, 5. IGES. IGES, for being a "solid" file format, has far and away been the most trouble of all the above formats. You should ask for IGES ONLY if their system cannot export to any of the other formats.
- - -Updraft
open the STL file as a solid body, I will then save it as a part file and have not had
issues then working on it. It's basically a dumb solid. It may take a bit longer
to work on, as the rebuilds are a bit more time consuming. The problem is, as noted,
trying to get large triangulated STL files to open as solids. Not always so lucky.
Going to the client to ask for the native part files would be great, except sometimes,
more often than not.. the files are coming from Asia... so not so easy to get the
useful files. From my original inquiry, I just wanted to explore all bases, if anyone
had some magical formula for getting the triangulation size down on the larger
STL files. But thanks for the help.
http://www.shapeways.com/tutorials/polygon_reducti...
I have not tried this program so cannot attest to it's usefulness.
and report back.
opening an STL file as a solid body requires the file to have less than
20,000 triangles, the Meshlab program allows you to lower the count of the
surface triangulation. I had an STL file that was 240,000 triangles. When
I tried to convert it 20,000, it didn't look so good. The geometry broke up
quite a bit. Still playing with it... but thought I'd report back on my initial
results. Thanks again to CBL for suggesting it.... maybe I just need to understand it
a bit more.
I would like to see if the Autodesk Mesh Enabler will convert a file with that many triangles to a solid.
See if this helps ... http://www.swtuts.com/?p=427
I just found this similar post from Charles Culp under this link:
https://forum.solidworks.com/thread/44730
looks like it 's the same post.... or similar....
haven't had a chance to read it in total yet...
but thanks!!
They offer a free trial. www.transmagic.com
-Lou
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
@ TrajPar - @ mcSldWrx2008
= ProE = SolidWorks
trying the mesh reduction feature. Seemed to work okay. I also downloaded a trial of the Geomagic
Studio program which also has a feature for mesh reduction but also has other features like
being able to open OBJ files and then save as STL files... which is what I was looking for. But
now I've also found out about this plug in called Power Surfacing which seems to allow opening
of OBJ files. The advantage of this is it's functioning within Solidworks. So that's where things
stand. The Geomagic software seems pretty robust and interesting, but the idea of learning yet another
program is less appealing than having a program that functions from right within Solidworks, (and offering
subD surfacing features)....like the power surfacing plug in.
