How to check applied force?
Hi
We have these series 4 pemserter on which I can set the force to a required value and install clinch nuts on to aluminium parts. But I would like to know what is the applied force on the part during pressing as sometimes there may be leaks in the pneumatics/pressure loss etc. Should I use a load cell to get an accurate force interpretation or can I just go with whatever the dial states.
V.
V.
RE: How to check applied force?
http://www.pemnet.com/presses/pdf/ps4/English.pdf also has contact information for factory help.
Personally, if the company has the budget for it right now, I'd buy a load cell, sized to deal with the pemserter and whatever other stuff might present force questions down the road, when maybe the cash won't be there.
Actually, a load cell and display should probably be in regular use by your QA department, should you someday have one of those.
Mike Halloran
Pembroke Pines, FL, USA
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Otherwise it's like calibrating a speedometer when it's known the needle sticks.
