Contact analysis in MFS
Hi everyone,
I am trying to use MFS to perform contact analysis in electrostatic simulation.
You may ask why I am not using trans126 or solid226. Trans126 did not consider so much fringing effects and my tilting angle is greater than 10 deg. Since displacement is great, solid226 will also create meshing problem during pulling in.
I wonder whether any of you coupled MFS with contact analysis before and would like to share the experience. Thanks!
