General cleanliness call out? What is the best way to do this without going overboard.
I am product engineer working for a company that makes medical blood analysis equipment. We do not make anything that touches a patient; it is all just lab equipment. My company sells mainly to second and third world countries. The market we cater to is small labs that can't afford big name analysis machines. This is all important because I need my drawings to reflect that in the sense that I can't spec something up because if I do, our price per piece will shoot up and then we need to pass that onto our customers and they can't afford it.
So with all that being said, does anyone have any suggestions about how to call out a clean part? What I am looking for is if a part gets machined, that it gets rinsed off, maybe tossed in an ultrasonic cleaner to get all large particulate off, and then blown dry with filtered dry air. That’s all. Parts don't need to be incredibly clean, just decent. I know this is ambiguous so it makes it impossible to say there is a pass fail, but I need to put something on there so clear things up.
Finally, being a small company, we don't have very much equipment. Just microscopes and magnifying loupes, and those are not even over in out inspection area. We use those things for production, but could bring them over if need be.
Either way, just want to hear some opinions.
Thanks.
Thanks.
RE: General cleanliness call out? What is the best way to do this without going overboard.
TTFN
Hydraulic oil for offshore umbilicals has some cleanliness specifications which you might find similar - they can be very tight, but come in a range of cleanliness levels. I've never got involved in it, but I'm sure a decent search will provide something or a slightly different post in the controls section asking for details.
I guess I can state to what micron the filter needs to be. That’s fine, but that doesn't really address the issue. I can have the parts air dry, I don't mind. What I really want is parts that don't have finger prints on them, no oil from machining and don't look like they got dragged around outside before being delivered to me.
I need to have a loose spec because the small machine shops I deal just simply can't spend time/money with high level cleanliness specification.
I would like parts to be decently cleaned like I stated earlier. I guess I can simply state that on each of my drawings.
Something like: ALL PARTS TO BE CLEANED WITH ULTRASONIC CLEANER FOR A MINIMUM OF 15 MINUTES WITH ONLY DISTILLED WATER. PARTS TO THEM BE DRIED BY FILTERED COMPRESSED AIR TO A MAXIMUM OF 0.3 MICRONS. NO FOREIGN MATERIAL PRESENT ON ANY SURFACE ALLOWED.
I know this is not a Standard Spec I am shooting for. I don't have the luxury of doing something like that. I need something that is "cheap and works".
I know this is not the world most engineers live in, but it is one I find myself in now and need to try and find a solution to this issue.
Thanks for any insight.
Are there fabricators out there who specialize in ultra clean stuff?
Since you require all of your stuff to be clean, this might be a task to bring in-house. Then, you know you cleaned it, and you know what you cleaned it with.
JHG
Well, that's really clean.
You need to specify either the process that you want used, or the result you want. Not both.
A Google search for cleanliness requirements for medical devices turns up a lot of useful looking information.
or anti-microbial ? exposure to UV ?
i like the suggestion above ... try something, assess it in-house, did it do the job ?
Quando Omni Flunkus Moritati
This is a land mine. You're best bet is to create a cleaning/handling/packaging work instruction as part of the drawing.
Only other thing I can correlate this to is how I get parts machined out of metal and tell the machinist to break all edges or smooth them. They don't ask how much material to remove when breaking an edge, they just know to take off a minimal amount so that edges that are 90° (or whatever angle) are not going to hurt you if you grab the part.
If there is no spec like this, please let me know. As for the breaking edge bit, what do you guys have on your drawings for something like that?
http://www.carolina.com/science-lab-filtration/fil...
If you can't get into precise numbers, I don't think there's too much wrong with words like clean, smooth, dry, free from grease, metallic particles or any other contaminent. They have common meanings which are well understood and would hold up in any dispute.
The main things we control are
- Largest allowed particle
- Maximum no. particles per size range of particle
- Maximum mass allowed in total
- Particles/materials of particular kinds (allowed/not allowed)
The different levels of cleanliness of course have different bogies for each. There are also some special requirements for certain component types which are listed separately, and some tips for how to correctly measure the above parameters.
In your case you would probably need to start the development of such a spec with a benchmarking excercise to determine what is/isn't acceptable in your case(s). No point in trying to control something if you don't know where to set the knob.
However, quantifiable and verifiable entails cost, plain and simple. If you don't want the cost, then you have to have a dodgy spec. That's just the way it is. If you impose a numerical spec, the inspection costs will increase 10-fold, unless your supplier already does that level of testing as a matter of course.
TTFN
GC (Generally Clean) (1) Freedom from manufacturing residue, dirt, oil, grease, processing debris or other extraneous contamination. This level can be achieved by washing, wiping, blowing, vacuuming, brushing, or rinsing. The GC level shall not be designated for hardware that is sensitive to contamination.
And this is from the Johnson Space Center 1998 for spacecraft.
Not a single quantifiable thing, anywhere in that paragraph. And in case you think that was an anomaly, here's the next level:
VC (Visibly Clean) (2) The absence of all particulate and nonparticulate matter visible to the normal unaided (except corrected vision) eye. Particu- late is identified as matter of miniature size with observable length, width, and thickness. Nonparticulate is film matter without definite dimension. This level, with the exception of the Orbiter payload (cargo) bay, payload canister and payloads, requires precision cleaning methods, but no particle count.
Only in the NEXT level are there quantifiable things:
VC + UV (Visible Clean Plus Ultraviolet) (2) Visibly clean (as defined above) and inspected with the aid of an ultraviolet light (black light) of 3200 to 3800 Angstroms wavelength (3.2 x 10-7 TO 3.8 x 10-7 meters).
And that only specifies the test method, not the results. Only on the next page do they start to get into "precision particulate levels."
TTFN
True. But vague and unquantifiable creates risk, which also entails cost.
If it (pictures) is good enough for the Swedish standard for how to rate blast clean standards for pipe it's good enough for your purposes.
Lots of people want quantifiable requirements, but are unwilling to pay for the implementation costs, so they cheat elsewhere, by either not testing, or testing inadequately, thereby not only incurring the risk anyway, but also creating an illusion of rightness.
TTFN
TTFN
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
With vague requirements the supplier never knows when, how many or why a part may be rejected and returned for rework at his expense.
A clued-in supplier recognizes that, and includes a factor in his price, hence it will be a direct cost to the vague specifier.
However it seems likely that the OP's company is not dealing with clued-in suppliers.
Our attempt at a general note which is of varying success:
FINISHED ARTICLE SHALL BE FREE OF OILS, LUBRICANTS AND OTHER CONTAMINANTS PRIOR TO BEING PLACED IN SEALED BAG.
For really clean parts we have serious cleanliness requirements based on our industry standard.
FINISHED ARTICLE SHALL MEET CLEANLINESS REQUIREMENTS OF IEST-STD-CC1246D LEVEL 100 (VERIFY CORRECT LEVEL). IF NOT TO BE USED IMMEDIATELY THEN TO BE ENCLOSED IN PACKAGING TO IEST-STD-CC1246D LEVEL 100 (VERIFY CORRECT LEVEL) LABELED: “CLEANED, DO NOT OPEN OUTSIDE OF CLEAN ROOM”. COMPLIANCE WITH THIS REQUIREMENT BASED ON USE OF A QUALIFIED MANUFACTURING PROCESS IS ACCEPTABLE.
ITEM SHALL BE ASSEMBLED IN A CLASS 6 (VERIFY CORRECT CLASS) CLEAN AREA MAINTAINED AS PER ISO 14644-1. (CLEAN AREA TO FED-STD-209, CLASS 1,000 (VERIFY CORRECT CLASS) IS ACCEPTABLE ALTERNATIVE.)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Anyways, thanks for the insight to all. I will pass the NASA style spec past my boss and see if he likes it. (He is not an engineer, but heads my department anyways.)
If everyone plays nicely, such specs are usually not that much of a risk. And in a competitive environment, most suppliers bet on the come to ensure getting the job, rather than pricing for failure.
TTFN
