wood screw values for structural panels to main members
Does anyone know where I can find load tables for wood screws for fastening structural paneling to main member lumber? The NDS gives values for nails but not for wood screws.
Thank you.
Thank you.
RE: wood screw values for structural panels to main members
Actually section 11.1.1 of the NDS states that all the tables are for Sawn, SGL, SCL, I-Joists and wood structural panels.
Mike McCann
MMC Engineering
Some manufacturers will likely have ICC-ES Reports on their products, for use/design and code acceptance purposes. Go to a good construction hardware supply house, with known suppliers, rather than a big box store buying from China, and ask for data and reports. Try Fastenal, they have darn near everything in the way of fasteners. There are so many variations, materials, sizes, etc., that there would be no way NDS could tabulate them. The same thing has happened with the bastardization of nails. We used to know what spikes and nails were, but now there are a million variations.
