Clipping an image
Clipping an image
Essentially, I would like to insert an image file and crop it. I can do this, but can no longer move or select said image after cropping.
In AutoCAD I would use the command "imageframe On/off" to show the images frame and then select/move accordingly.
Here are the steps I've taken... am I missing something?
1) Insert - Reference Image
2) Select image, copy, paste as block (can't seem to clip if just an image and not pasted as a block)
3) Select block, Modify - clip - reference - boundary - rectangular
This gives me the clipped image; however, I can no longer select the image (to move, delete etc...) unless a portion of the original "frame" is unclipped.
Any help would be appreciated.
