Vessel false bottom with cast concrete
To get a flat level at the bottom head of a backwash vessel, our contractor is suggesting to cast concrete inside the head.
Someone, please, has an idea on how the process is done and how, in the future, the inspection of the said head can be performed?
RE: Vessel false bottom with cast concrete
I would suggest a foam concrete to keep the weight down.
In case of any internal damage resulting from corrosion? how to repair?
Thanks again
