"one or more contact regions may not be in initial contact"
Dear All
I am using ansys 12.0. while solving structure problem (snapshot attached) i am getting error "one or more contact regions may not be in initial contact). as it is welded structure so bonded connection is used.
anyone can help me to know what can be possible cause for this and what can be done to avoid it??
Inder
Inder
RE: "one or more contact regions may not be in initial contact"
here i am attaching snapshot of deformation observed.
Inder
Inder
Also check the information on contacts status before solve (in the connections section), it can sometime be useful.
i have not given any clearance in any of contact.
Can that be reason for such error???
Do i need to give some sort of clearance(in model) in case of bonded connection( or any type of connection)???
Right click on Connections > insert > contact tools, and check the informations given at this point (don't hesitate to check other things than only "initial information", like status, gap etc...)
Same thing on solution, insert > contact tool, then same process.
Check your contacts to see which one(s?) is(are) the source of your error
i can see many contact region showing as far open and marked as red in initial information.
I suppose if i can fix it i can get rid of this error.
thanx a lot orel.
That is probably the cause of your problem, hope it will fix it.
Do i need to fix my model or i need to make some other changes to get rid of such error??
what according to you i did wrong to get such error???
Maybe there is a geometrical gap at some contact region. If so, you can either add material fill it geometrically (increase the diameter of the inner part for exemple) or switch to manual pinball radius and set it to be higher than this gap.
