Power supply for monitoring from solar Inverter
Does anyone know if following is true or there is a code on NEC regarding this?
"In systems covered by the NEC, ac power cannot be pulled directly from the inverter output, and a different circuit must be used." from following article
http://solarprofessional.com/articles/products-equ...
