Mixing Welds and Bolts...
I am involved in a project that is currently in the construction phase. While out in the field and inspecting some of the moment connection welds, we noticed several instances where several of the shear tabs were welded off to the beams. These beams are cantilevered and moment connected. When asked why several of these pieces were welded off in addition to the bolts, the contractor said the welds were done to level/plumb the steel. The connection in question is to the right of the uploaded picture. AISC 13th edition, Section 16 Chapter J1.8 states that "in such connections the available strength of the bolts shall not be taken as greater than 50 percent of the available strength of bearing-type bolts in the connection". If this is the case, would this mean that the weld would essentially need to be designed to take the full shear capacity of the connection? We have asked for the contractor to remove the welds, but worry that if they burn/grind too much that the beam web may be damaged. Any opinions for a course of action?
Thank you
Thank you
RE: Mixing Welds and Bolts...
I have a hard time seeing this as a dangerous condition. Have you checked tbe connection against the combined bolt and welds provisions?
The Engineer is the individual responsible to determine if deviations from the design have a negative influence on the performance of a connection.
The structural welding code has a clause that addresses unauthorized welds. Unauthorized welds are a nonconforming condition that must be reported by the inspector. The inspector is not in a position to determine whether the unauthorized weld has a negative impact on the design. The inspector's function is to verify the contractor has implemented the design provided by the Engineer. Any deviation should be noted in the report so the Engineer can review the situation and make a determination whether corrective action is required. The inspector should not provide direction to the contractor on how to accomplish the corrective work required by the Engineer. The "how to" is the responsibility of the contractor.
Best regards - Al
Thus, agree with the constructing manager, and tell him that "doubling connections" by welding and bolting is fine, and can be used. As long as there is no extra charges for the extra work nor any schedule delays for the welder and his setup on top of beams and girders and scaffolding.
Then smile and tell him to NDE that weld and grind out all indications (porosity and embedded grit and coatings) and leave a smooth, clean acceptable weld on your building, and give you the NDE results for each field weld left at joints.
His "logic" (excuse?) for "leveling/plumbing" the steel using a weld is back-asswards. BOLTS and their inherent slop allow such movement, a fixed weld cantilevered out from the theoretical center point (work point) of a joint prevents movement or adjustment. Unless that was the intent of his excuse: "We needed to lock the joint in place so we could wedge something else into the right place, but we didn't want to tell you that the other piece of steel didn't fit .... "
“Faith is taking the first step even when you don’t see the whole staircase.” MLK
The only other thing you need to look at is that the weld is a good (i.e. no notches). So it needs to be inspected. gtaw is right on about that. I would be hesitant to make the contractor rip them out unless you can definitely say what is wrong with the as-fabricated connection.
If you are the designer, keep in mind that ~50% of the beam's shear resistance is now in a Heat Affected Zone, this may or may not change your governing design case. See the attached picture for a bolted/welded connection done wrong.
Michael.
"Science adjusts its views based on what's observed. Faith is the denial of observation so that belief can be preserved." ~ Tim Minchin
Michael.
Best regards - Al
The "weld" is truly terrible and clearly won't take any serious load, plus appears to be done on two sides only. Is it an optical illusion or is the top bolt bigger than the bottom one?
Are washers still acceptable on this type of joint? In piping connections they were banned years ago as it was not possible to guarantee their strength and could hide some large defects in the bolt / hole size and essentially all your bolt shear was going through a rather thin steel ring of unknown strength.
Feel free to ignore - just some general observations
I'd heard of piping connections not using washers, and I always wondered why... Now I know. Thanks for that.
For your information, washers are still standard practice as they "eat" or make up for the oversizing of our holes, and do not interfere with strength. In your case the bolt holds the pipe together more or less principally against tension. In nearly all structural steel connections, the bolts are working principally in shear. The washer is there to keep the bolt from pulling out as bearing loads get high; Even a low-grade bubblegum quality steel would likely do the job we need.
Interestingly there are even tension-indicating washers used in Structural Engineering which can tell you when a bolt has been correctly tensioned for slip-critical connections. You're not meant to rely on them alone, but a lot of engineers and erectors do.
The temptation is then to use a washer which is bigger in OD than the OD of the nut to hide the fact that there is no steel under the bolt and a lot of your tension goes through the washer. That's how you get pull through, not by using a washer which is the same OD as the bolt. I've never heard of these special tension washers before though...
As hokie66 says, take one bolt out at a time and have a look.
As to the possibility of anything being wrong, I have been known to insist on a bolt or two being removed to satisfy me... I see this as being little different than any other situation where something I need to see has been concealed.
The flanges look to be beveled as if they will be welded. Why the web stiffeners otherwise?
@LittleInch - The special washers squirt a little colored goo out when they are squished the correct amount (intending to directly indicate the pretension applied to the bolt). But you wouldn't likely use the twist-off type bolts with the washers.
I guess I'm just so used to not seeing washers on bolted items that it makes me wonder what purpose they serve, but I admit I'm in the wrong forum here.
We don't seem to have heard from the OP on this thread - any response from you?
I'll shut up now
But it sounds like this is a moment connection so maybe that becomes moot, not sure. I think if I am signing off on this I have them grind it off and be done with it, takes a couple of minutes.
Using hardened washers under the turned element in a high strength bolted connection has always been the norm for structural work. It is not to conceal oversized holes, but in this case a problem with the hole locations is the only reason I can see for the temporary welding.
vvaccare,
Where are you?
Also the ink spitters are a new variation on the old theme... They are still much less common than washers that simply squish, and much much less common than regular washers.
The tolerance of an extra 2mm in the bolt holes beyond the bolt diameter is necessary in structural steel erection to allow for long do mentions sometimes in the hundreds of feet to actually work. Nothing would ever have fit before laser surveying without this tolerance, and I'd hazard a guess that few things would today either!
One more thing, those twist-off bolts are only reliable as tension controls when the spline is broken off soon after the bolts are removed from proper storage. As the spline is still on the ones in the picture, I doubt that you can depend on the tightness.
BA
BA, they have an installation tool where an inner sleeve grabs the end of the bolt while an outer wrench, grabs the nut. They torque against each other, no need to grab the bolt head, that's why it is round. The end held by the inner tube, breaks of in the torsion range to provide the correct tension. The tool is electrical,like a big drill, so they don't need a compressor operator.
We didn't have any bolts fail to make the range as long as they were fresh and the lubricant film was still on them.
There is a QC component in that you can see if the end has been torqued off.
Michael.
This method usually defaults to "twist-off" bolts, sometimes called "tension-control" bolts. These assemblies function by calibrating the torque needed to twist off a splined extension manufactured into the bolt shank. Made correctly, the "twist-off" will occur at a bolt tension above the minimum required.
The main advantage of "twist-off" bolts is that they can be tightened from one side by one person, although bolt installers now realize that regular hex bolts and DTI's can also be installed one-side, one-man, too.
There are a number of disadvantages to the "twist-off" system:
Special wrenches are needed.
Special connection clearances must be detailed for wrench access.
Frequently more expensive than hex bolts and DTI's.
Galvanized twist-off assemblies are in VERY limited supply.
Field relubrication is prohibited by code.
Compacting plies must be accomplished prior to twist-off.
Deterioration of the thread condition for any reason will change the torque-tension relationship, and Kulak has shown in an ASCE paper that in as little as three days out of protected storage, one-third of all the twist-off bolts he tested did not develop the required tension at break-off.
BA
gjc
Snugging entails going around the bolts several times when there are many bolts or if there are wide gaps between the plies, similar to re-installing the wheel of your car with a hand wrench.
Michael.
That is a common sequence, but according to the literature, the delays between steps would have an adverse impact on reliability of tightening of these twist off bolts.
The main way I can see a contractor benefitting financially from use of these bolts is relaxation of inspection requirements. If breakoff of the splines is accepted in lieu of inspection by other means, and the contractor was required to pay for inspection, then he would benefit. But being the cynic that I am, I wouldn't buy it. Another thought...those splines can easily be removed with a pipe wrench, so if no one is watching, he doesn't even have to have the installation tool.
Michael.
Oh, I concur with your opinion that the weld "could be" covered with slag. It most certainly is STILL covered with welding "fumes" and the surrounding metal has never been cleaned or wire-brushed.
Thus, my opinion of the "bad quality" of the weld: If the welder (and his supervisor/foreman/accepting engineering or boss) did not care enough to even clean off the weld, how does anybody know how good a weld is on the joint between two pieces of steel up in mid-air? If the welder does not even "brush off" (chip off) the slag, how does anybody know how long, high, wide, or evenly the weld itself is?
Obviously NOBODY inspected the weld - "No body" could inspect a weld still covered by slag and with fume residue on the base metal! The weld should either be inspected by a qualified NDE or removed.
You only see stud bolts (without washers) on piping connections as there were failures of the bolt head due to the high stress concentration at the head / shaft interface, which just doesn't exist with a stud bolt and nut and is very difficult to spot being on the inside. Similarly washers don't make sense as they don't do anything - Only if you're nut is considerably harder than the structural steel (I hope not!) does it make sense and the risks e.g. non hardened washers, slightly oversize washers, allowing use of undersize bolts - are not worth the miniscule advantage of having washers. IMHO that is.
We still await feedback from the OP....
These projects were in central Wisconsin 15+ years ago. "Inspections" were not required as things were much simpler then. I was with the Owner's engineering department and was the structural project engineer when this came up. We designed the building and then observed the installation procedures, but the State permitting did not require the independent inspections that are now "required". We did observe some of the connections being installed, but certainly not all. When the splines were off, we assumed that the connections were OK.
At the end of the project, as the EOR, I verified to the State that the building was constructed in conformance with the drawings and specification. We were then granted the occupancy permit.
We then adopted these bolts for our smaller projects which were done by our in-house trades. We bought the wrenches and ordered the bolts with the feeling that there would be a net cost savings. Maybe that was wrong.
gjc
Michael.
Thanks again everyone!
One of the few locations that (F436) washers are actually required in structural connections is when using pretensioned A490 bolts and the material being connected has a MSYS of less than 40 ksi.
Thanks for the gracious invitation, but no thanks. I'll avoid California.
vvaccare,
Did you check to see if they had enlarged the holes, also due to fabrication error?
BA
Although we are seismically active here, I think many modern structures are very safe because so much attention is put into the detailing of the structures.. especially steel moment frame buildings. After Northridge earthquake the industry went nuts on weld procedures and detailing of SMRF's.
When you have seismic design category "D" and all your drags are designed for overstrength, double row of 1" dia A325SC (with twist offs) are often used at every beam to col connection along the drag line.
You guys should come on down to Florida! Nice weather and no worries about seismic design here! Just wind and the occasional sinkhole!
BA
