I want to import drawing notes "text files" from a folder on my C: into a drawing
Jeff is back,
In Pro-Engineer to add the notes to a drawing from a location outside the cad tool you do, Insert, note by file, make note click in the screen and a window opens and you browse to where ever the file is click on it and it's added to the drawing.
In NX I go to annotation, note, import/export, click insert text from file and a window opens and you browse to where ever the file is click on it and it's added to the drawing.
Now in Solidworks I do insert, annotation, note a window opens I do not see anything that allows for importing a note from a location outside the tool.
Once again your help will be appreciated.
Jeff
RE: I want to import drawing notes "text files" from a folder on my C: into a drawing
Copy from Text file and paste into an annotation works real good as well.
Scott Baugh, CSWP pc2
Berry Plastics
Cad Admin\Design Engineer
GEASWUG Greater Evansville Area SWUG Leader
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
You can also embed files.
Create MS Office file. Then drag and drop into SW. You can edit it from inside of SW afterwards.
