Large Diameter Flange with small hub thickness vs thick pipe
Hi All,
I encounter a question which would like to discuss. I have a vessel, OD 46"(1168.4mm), have one side SE2:1 dish head another side end with large diameter WNRF #300 flange (46") with blind as a manhole.
Design Pressure: 50 bar
Design Temp: 50 degC
Shell using 1"(25.4mm) Boiler Plate. (Minimum calculated required thickness is 22mm)
Available large diameter flange 46" seems to only available in two thickness which is sch std(9.53mm) and XS(12.7mm).
If i follow the welding method according to ASME VIII Sec.1 UW-9,
removing the thickness from shell plate will result the actual thickness less than required thickness calculated according to UG-23(c).
Any suggestion?
wcw
Any suggestion?
wcw
RE: Large Diameter Flange with small hub thickness vs thick pipe
How else can that part of the PV be rated at design conditions?
However, Ive never worked with B16.47, so Im not sure if u can order these as B16.47 series x 46" x 1" wall thickness, WNRF Cl 300
Even i check from Texas Flange website, they only have sch std and sch XS for such size of flange.
Anyway thanks for reply.
You may have to find a vendor who will let you do so.
Mike
Texas Flange will certainly supply a flange with any bore you specify.
The table you were looking at Flange Wall Thickness is very poorly labeled. This is just a typical pipe schedule table for if you're using pipe components. I'm guessing at 46" you're not using pipe anymore, so your wall thickness doesn't match the table.
If you look at their tables labeled ANSI B16.47 SERIES A FLANGES, you'll see that the bore dimension is "to be specified by purchaser".
The OD of the flange where you weld to the pipe will match the OD of the nominal pipe size, in your case 46", but the bore must be specified by the purchaser.
Cheers,
Marty
wcw
