Heating in a pipe
Heating in a pipe
need suggestions for heating fluid in a small section of pipe from 80 to 150F. Space is limited
RE: Heating in a pipe
B.E.
You are judged not by what you know, but by what you can do.
Good luck,
Latexman
Technically, the glass is always full - 1/2 air and 1/2 water.
Have Fun!
James A. Pike
www.xl4sim.com
www.erieztechnologies.com
You need to provide much more information to get a good answer.
Continuous?
Once in a while?
Only in emergencies?
How much space around the pipe?
Above ground or in basement or in an open room or under water or ....?
What fluid, what pressure, what margins or concerns about safety?
Continuously monitored by a person?
Remote site with no people around/
Done by qualified operators under supervision, by plant employees permanently employed, or maintenance personal with no training or by unskilled labor and likely no discipline or care?
So, the fluid in the "pipe" heats up. How are you going to control or limit pressure rise?
Vapor production in the pipe?
Fluid itself from burning or charring or breaking up (like a food production line of butter or liquid soap or paint or lubricating oil?)
How fast is the fluid flowing? That's a major constraint on how much heating is required? mass flow times specific heat times delta temp.
TTFN
