Modelling of boiler combustion air system
I have an assignment to model an existing boiler combustion air system, in order to advise on fan upgrades that would be required to meet revised air flows that the end user requires
The system is quite complex with several fans and fresh and recircualted air being mixed at certain points
I am looking for suggestions as to a suitbale software to model the existing system and also trial changes in fan / fan impeller size to achieve the revised air flows
My search so far has found software designed for HVAC which I don't think really fits this application
The more powerful software such as PlantFLOW and Hysys are expensive and I think overkill for this exercise.
I am expereinced with using Pipe-FLO software for centrifugal pumps and ideally I am looking for a similar sofware which allows me to enter fan curves and then asses fan duty / performance at different operating scenarios
I could do the exercise via spreadsheet but if I can find suitbale software it would make the whole exercise more efficient
Any suggestions as to suitbale software that is not too expensive? (I have also posted this on the pipework forum!)
RE: Modelling of boiler combustion air system
From the H.S. (in Sq.Ft.) values, you can determine their steaming capacities (S.C.'s) in Lbs/Hr for power steam boilers or heating rate (Btu/Hr)for hot water boilers which are used to rate the relieving capacities of their safety or relief valves. The terms safety valves is used for steam boiler and relief valves is for hot water boilers. The ASME code I and IV has the factors needed to multiply the H.S.(in Sq.Ft.)values to find the steaming rate in Lbs/Hr. Note for a steaming capacities in LBS/Hrs, you must multiply that value by 970 Btu/Lb to convert to Btu/Hr.
From S.C. in Btu/hr, you can determine the heat output of each burner as long as you can approximate the heat transfer efficiency from the firebox to the boiler heating drum and that value is somewhere between .75-.80 with boilers manufactured within recent times (i.e. in the last 40 years or so)) Knowing the burner heat output, you can estimate the burner heat input(in Btu/Hr) as long as you know the burner efficiency and that value is estimated at 80%.
From burner heat input (BHI), you can determine the amount fuel in GPH or CFH to the burner, depending if you burn oil or gaseous fuel. From BHI, you can then determine the amount of combustion air which must include excess air in CFM. Excess air value depends on the fuel burned. If you are lucky enough, burners will have fastened tags or permanent labels showing the minimum and maximum fuel consumption which you can use to determine the combustion air moved by the forced draft fans.
There is an abundance of literature on these subjects. I know that libraries of communities that have or had industrial sectors have books by such author as Shield which you should research for a better understanding of what you are trying to accomplish.
