Simple Mechanics problem - stepped shaft uniform load
I need to know the general stress equation for a stepped shaft with a uniform load on section 2. The reactions R represent roller bearings, and are located at their centerlines. I don't know which equations from the charts to apply to each section. Thanks.
RE: Simple Mechanics problem - stepped shaft uniform load
section 2 is not very clearly shown ...
Quando Omni Flunkus Moritati
btw, why in the FE forum ? checking a model result ?
As far as the forum, is there a better subforum for these questions? This is basically "homework help" but yes I am trying to validate a model.
I am trying to develop a standard 3D setup for briquetting rolls for FEA. The problem is I don't have access to 2D software (I have ProE mechanica basic), the engineer that usually does this analysis is located off site and uses 2D models, which I am essentially copying and trying to do by hand.
please take your question to your TA or peer group.
the moment in the beam is easy to calculate ...
assuming simply supported, length "L", then end reactions are (w*a)/2 ... where "a" = the length of the distributed load "w"
then define "b" = (L-a)/2 the unloaded length at each end of the load, yes?
then for x<b, M = Rx = (wa/2)*x
and for b<x<a/2, M = Rx-w(x-b)*(x-b)/2 ... Mmax(x=L/2) = RL/2-w(L/2-b)(L/2-b)/2 = waL/4-w*a/2*a/4
and the stress = My/I = M(d/2)/(pi*d^4/64) = 32M/(pi*d^3)
the reaction is the same in both cases, no?
