Save Failed (NX8/Teamcenter 9.3)
Does anyone know the cause or solution to this failure? The odd thing is that I can't save it, but the guy right next to me can... After he saves it, I can save it again!
RE: Save Failed (NX8/Teamcenter 9.3)
This is probably a GTAC case.
I believe that your Teamcenter setup needs a little help.
Tomas
Plz try to Run the part clean-up from utilities / check the connectivity between NX and TC / try to login the other m/c using ur ID and try there you able to save or not. ensure both(you & ur neighbor) are same group in TC or there is any different. or you might have the reviewer access? without the NX part file we can't find the exact reason.
