Bearing Failure Causes.
Gents,
Attached are a photo of a self lubricated journal bearing installed on the drive end of a centrifugal pump driven by 5.5kv
motor.
The bearing failed after being heated up then the temeprature transmitter sent a high temperature alarm(setting alarm: 85 C).
I would be grateful if you could help me on finding the bearing failure causes based on the attached photos by interpreting
the impacts on it. Please note that only the lower half of the bearing which was affected.
Thank you.
motor.
Thank you.
RE: Bearing Failure Causes.
Mike Halloran
Pembroke Pines, FL, USA
I would inform you that the bearing bolts were equipped with hollow dowels but not shown on the attached picture above.
... except that maybe something got bent.
... like the narrative about what really happened, while on its way to you.
Mike Halloran
