Mar aging Steel
Mar aging Steel
does anyone have experience of MARAGING STEEL shinkage during heat treatment?
I understand that it can shrink approx 0.0004" per inch on external diameters. Does the same apply to internal bores and a linear reduction in the actual measured diameter occur, or is it a case where the cubic volume of the material decrease and the measured diameter of an internal bore would effectively;y increase?
Thanks in advance
Thanks in advance
RE: Mar aging Steel
Maui
www.EngineeringMetallurgy.com
RE: Mar aging Steel
These are volumetric changes, either all dimensions increase, or all dimensions decrease.
Plymouth Tube
RE: Mar aging Steel
