SAP2000 CQC Mode Combination
Hi all,
So, I have a complicated building structure that I've modeled in Sap2000 v15. I'm trying to determine the shear forces acting at each concrete wall in my model. I’m checking my model by comparing the sum of the reactions at the base joints to the base shear output as given in the table. When I run the static analysis this works; the sum of the reactions at the base joints matches the base shear perfectly.
However, when I run the dynamic analysis (which I am required to do per code), the sum of the reactions at the base joints is about twice as much as the base shear output. I'm assuming this is because the modal/dynamic analysis shows the worst case forces, so my "envelope" reactions are much greater than my base shear. Is there a way to determine the actual forces acting at each wall? Are there specific modal or dynamic analysis settings that I can change so that the sum of the base reactions approximately matches the base shear?
Per CSI Tech Support:
"If you were to calculate the base reaction from the results, you will need to multiply the modal reaction values from the "Base Reactions" table, by the response spectrum modal amplitude values in the local U1direction "U1Amp" shown in the "Response Spectrum Modal Information" table. After combine the calculated response spectrum reactions you will obtain the same result as shown on the "Base Reactions" table."
I'm not quite following this, but it seems to imply that I need to recombine my modes by hand using the CQC method, and then combine the forces using SRSS. Does anyone have a practical method for CQC combination of the all of the modes?
RE: SAP2000 CQC Mode Combination
If you try to integrate the forces at each joint manually, as CSI support already told you, you'll be done by next year only...
