How to copy in assembly a used curve to my work part without "Sketch Plan on curve"?
I have a sheet with 2 side thicknesses, made from an curve>extrude. But this is not the work part. I like to use this curve for
my work part, to make a guide swept along this curve (with a normal plane to this curve).
How can I copy this curve to my work part? OK, maybe with a plane ON this curve with a sketcher would be working, but I like a 3D solution. My work part is invisible because I just started it. The curve is part of a different assembly part.
Attached is my model and a jpg.
Thx
Thx
RE: How to copy in assembly a used curve to my work part without "Sketch Plan on curve"?
