High temp bearings.
High temp bearings.
We are trying to source 2 bearings with external gear, similar to a slewing ring. Max od 519mm ID = 341mm This is to support a horizontal rotating high temp incinerator made from a special type ceramic. The problem is that the ambient temp is too high for the bearings.
We were wondering if anyone knows of a oil or water cooled bearing or technique.
The temperature at the bearings is in the order of 600-800 deg. Cent.
Within the tube ( reactor ) it is approx 1800 C .
RPM is approx 3-5 rpm... All is housed in a nitrogen purged st/st tank.
We have tried most major bearing mnfrs. But zilch. Help, or are we trying to do the impossible.
RE: High temp bearings.
I'm the engineering design manager at a bearing manufacturer, send me your problem, and I will forward it onto the relevant people.
Quick Note: The highest we have done successfully is 240 deg.C, but we love a challenge.
nigel_hoyle@eu.fmo.com
If you have already approached us try DEVA in Germany
