Rules for sizing anti-siphon holes? - Part 2
thread378-293910: Rules for sizing anti-siphon holes?
All,
It has been some time since I posted this question (see the above thread), but in the meantime I stumbled across a different solution to this problem. Somewhere I found the suggestion to use a long piece of angle iron or even just a long rod to connect the nozzle to the bottom of the tank instead of using a dip tube with an anti-siphon hole. The angle iron electrically bonds the hydrocarbon stream with the bulk fluid in the vessel and there is no concern about an anti-siphon hole plugging.
Does anyone have any experience with this kind of thing? Is there something else that can go wrong here that I'm not thinking of?
JJJ
RE: Rules for sizing anti-siphon holes? - Part 2
I've seen a length of chain from the nozzle to the bottom of the tank/vessel used.
Good luck,
Latexman
Technically, the glass is always full - 1/2 air and 1/2 water.
