Android app for manual data logging?
Howdy all,
I am looking for an Android App that will do manual data logging. This seems like an easy search, except I'm inundated with specialized apps for watching your weight or tracking you car mileage. We have a process line here and there are a series of daily, weekly and monthly values that need to be recorded to track things like water usage, waste water pH, etc. I would like something where I can walk around with a tablet, look at a dial and record that value. I would also like it to be integrated with a calendar so I can have the schedule for all the different values to be recorded. I can come in pick up may tablet and know what needs to be checked that day, go around, check those values and be done. I'll keep looking, but I was hoping someone who has already faced this issue could point me in the right direction.
-Kirby
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
RE: Android app for manual data logging?
Many integrate with Google calendar.
-Kirby
Kirby Wilkerson
TTFN
https://play.google.com/store/apps/details?id=com....
Spreadsheets are a pretty obvious tool for entering data, but if you want something that is designed for ease of data entry and validation, and distinguishing between free text and numeric fields etc, then Forms might be a good tool. From the Google Forms help page:
Google Forms is a useful tool to help you plan events, send a survey, give students a quiz, or collect other information in an easy, streamlined way. A Google form can be connected to a Google spreadsheet. If a spreadsheet is linked to the form, responses will automatically be sent to the spreadsheet. Otherwise, users can view them on the “Summary of Responses” page accessible from the Responses menu.
https://support.google.com/drive/answer/87809?hl=e...
A huge advantage of using Drive is that it is easy to share (e.g. multiple users entering data in the field), and it will also be easy to access the data on a PC for aggregation and reporting - no need to export from your Android device and then import to your PC.
http://julianh72.blogspot.com
A form is coordinated with a spreadsheet to provide easy input including radio buttons, check marks, pulldowns, number fields, text fields, whatever you want.
I'm not sure how well it works if the device is not connected when gathering data. When I last looked about a year ago, there was no ability to input data while offline.
Something I use for my personal databases is memento database. Similar to Google Forms, it can give you a variety of types of fields for data input.
(2B)+(2B)' ?
If I were starting from scratch I would definitely look at Google Docs/spreadsheets / forms first.
(2B)+(2B)' ?
Yes, you're right - "Forms" doesn't work when you are offline, but Spreadsheets can be set-up to work offline (as well a Documents, Presentations and Drawings), so if the OP needs to allow for the possibility that the people collecting the data may not have an internet connection, then Spreadsheets might be a better choice.
https://support.google.com/drive/answer/2375012?hl...
(2B)+(2B)' ?
-Kirby
Kirby Wilkerson
Cheers
Greg Locock
http://www.droiddb.com/products/droiddb.php
http://www.ddhsoftware.com/handbaseandroid.html
Walt
