API 650 Tanks MAWP is tool low for conventional emergency vents
The problem is that the MAWPs on API 650 Storage tanks are too low to be able to utilize conventional conservation/emergency vents.
I am trying to re-rate the tanks to increase the allowable working pressure and lower the operating pressure of the flare/vapor combustor header.
Can anyone please assist.
Thanks!
Thanks!
RE: API 650 Tanks MAWP is tool low for conventional emergency vents
And a review of Atmospheric Storage Tank conservation vents and emergency vents from tank appurtanance companys -- Shand & Jurs; Protectoseal to name 2 -- will show that they are available down to 1/2 ounce per square inch. A 3/16" thick steel roof weighs about 0.7 osi.
