Determination of penalty radiography
Dear All,
is there any guideline in ASME Section I to determine number of penalty radiography to be taken if the joint fails in spot radiography? Or it is left to the agreement between manufacturer & purchaser?
Kindly reply.
Alok
Kindly reply.
Alok
RE: Determination of penalty radiography
I only have the 2004 Edition so it may be in a later edition (though I find it hard to understand where you would do spot radiography in a boiler)
DD
In Section I you have no choice like spot as you find in Section VIII-1 or Section VIII-2.
Nasir
Welding Engineer
DESCON ENGINEERING LIMITED
PAKISTAN
