Horizontal Forces from Vertical Forces
I have many Joint Loads > Forces (LOAD1) applied in the direction -z (vertical). However I need create horizontal loads (LOAD2) that is = 0,5xLOAD1 applied in the same joints in the direction y.
How I can do this without create the horizontal forces one by one?
RE: Horizontal Forces from Vertical Forces
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
