Low current consumption of pump working in negative suction
We have a centrifugal pump installed working in Negative pressure at suction side.
Rated Shaft power, P2 = 18.5Kw. Full-load current of motor = 32A. Motor has star-delta starter.
Please find the pump curve below:
http://files.engineering.com/getfile.aspx?folder=9...
The pressure gauge at the discharge of pump indicates pressure of 50m.
With an NPSH of 4m, this means that the pump head is at (50 + (10-4))=56m.
At 56m, the flow should be 67m3/h and P2= 15.4 KW.
At 15.4Kw, Current should be about 28A.
However when measuring the current on each phase, we get 9.5A.
Can you please advise what could be causing the motor to be running at low current?
thanks
thanks
RE: Low current consumption of pump working in negative suction
System head = total discharge head - total suction head
H = hd - hs
The total discharge head is made from three separate heads:
hd = hsd + hpd + hfd
•hd = total discharge head
•hsd = discharge static head
•hpd = discharge surface pressure head
•hfd = discharge friction head
The total suction head also consists of three separate heads
hs = hss + hps - hfs
•hs = total suction head
•hss = suction static head
•hps = suction surface pressure head
•hfs = suction friction head
If the pump is not operating on the pump curve, the pump suction may be partially blocked.
Motor:
Voltage, no phases (3?), power factor, rated size
Pump
Inlet pressure, outlet pressure, density of what you're pumping,
Is this a single pump or a parallel or series unit.
How are you measuring flow? If you pump less fluid then you use less energy. How are you measuring this?
Your curve is a little odd, is your flow capable of getting over the "hump"
I hate Windowz 8!!!!
You will need to accurately measure the flow / head and get back to us.
As BigInch has pointed out the pump could very be running left on the curve where the head at 56m is the same as it is at something less than 10m.
To check if this is the problem you need to start the pump against an open discharge so that it runs out until it hits curve and then runs up the H/Q curve - it should settle at the higher flow rate, if you then throttle the discharge and increase the head you can then check if it moves left to the lower flow rate, if it does it will stay there.
If the pump is started against a close valve or a fully charged discharge line, once it hits 56m then it will run there at the lower flow and won't run out on its curve to the higher flowrate.
"If the pump is started against a close valve or a fully charged discharge line, once it hits 56m then
it will run there at the lower flow and won't run out on its curve to the higher flowrate."
I should say "it may run at the higher flow as it runs up the curve or it may well move further left to the lower flow."No way of predicting either - only the onsite result will confirm where it will run - which in your case looks like the lower flow.
I feel that blockage or partial closure of some valves in the discharge side needs to be checked as this will also reduce flow and motor load.
