Water Intake
Water Intake
Does anyone have some water intake plans I could have a look at? I need to core through 90m of granite bedrock in order to install the intake. The size is 300mm dia.
Also, any idea on the approximate cost per meter for the intake through bedrock???
Joe
Joe
RE: Water Intake
Seriously, what do you think is going to give you a more accurate answer?
RE: Water Intake
I thought it may be possible that someone on this site has actually gone through the design, tendering and construction process for an intake.
What the tunneling companies say and what it actually costs in the field when the tap is turned on is usually different.
RE: Water Intake
At this point without detailed plans, I would use the higher estimate and try to get the project started.
