How to combine parasolids..
Hi all,
I have a part (.prt file), in which all components are bodies (para solids) and the list of para solids in the feature parameter is more than 100..
I would like to know is there any procedure to combine all para solids in to one or two para solids.
Please help me..
Thanks in advance.
Thanks & Regards,
Sam
RE: How to combine parasolids..
Sorry,
I forget to mention. Currently I am using NX 7.5
Thanks & Regards,
Sam
Unite them and export as a new parasolid?
www.nxjournaling.com
If they are all sheet bodies: Sew them together, and remove parameters. That will turn hundreds of bodies into one. If you are lucky enough, it will be a solid when you are finished.
