what is the difference between crus
what is the difference between crushing and compression
RE: what is the difference between crus
Though crushing requires compression, an object can be compressed without crushing.  As an example, a rubber ball can be compressed in your hand, but it is not likely that you can "crush" it.  Crushing implies damage or failure as a result of compression, while compression is just a state of stress.
