Software to make documentation
Which software I need to purchase to Siemens PLM if I want to make documentation like what can be done with 3DVIA Composer from Dassault ?
Thank you...
Using NX 8 and TC9.1
RE: Software to make documentation
You can take a look into Cortona (for technical publication).
Best Regards
Kapil
or Latice can be an option
NX 6.0.5.3
NX 9.0.0.19 MP01
Windows 7 64
Thank you...
Thank you...
Yes cortona integration will enable this change in the original assembly to reflect in the documentation. Sorry i worked on it quite a long time back so cannot comment on all of it's strengths.
Probably you can get in touch with one of your known Siemens representative to ask for more information on the same.
Best Regards
Kapil
I'm registred to Cortona3D to test for 30 days.
Thank you for the info.
Thank you...
Thank you...
The reasons are :
1) assembly or parts used to make documentation are always updated at any original change in NX via server synchronization
2) Software with modern UI
3) very complete tool
other software are far to Anark...
Thank you...
Using NX 8 and PDM RuleDesigner
