gm g body ackermann angles
does anyone know what the ackermann angles are for a mid 80`s gm g body 2 door chassis is?
RE: gm g body ackermann angles
I just made a few Google searches for alignment of a 1985 Monte Carlo and only cam up with the straight ahead settings.
Might need a factory shop manual for the good stuff.
and with in mind ill be using adjustable upper control arms i wont need the shims so i can just add one piece and tapered shims to find the right angles
What are you looking to achieve?
Have you seen some of the other threads that talk about when Ackerman is, isn't, or might be important?
Norm
