Concrete Inserts Specifications
Can anyone give me a link or a photo of the below concrete inserts that are specified below. Thank you!
"Carbon steel bolts having special wedge-shaped heads, nuts, washers, and shims and galvanized in accordance with ASTM A 153/A 153M. Provide slotted-type concrete inserts consisting of galvanized 1/8-inchthick pressed steel plate conforming to ASTM A 283/A 283M; of box-type welded construction with slot designed to receive 3/4-inch diameter square-head bolt with knockout cover; and be hot-dip galvanized in accordance with ASTM A 123/A 123M."
RE: Concrete Inserts Specifications
Maybe something like this? http://www.halfenusa.com/t/25_11867.html
http://www.anvilintl.com/products/pipe-hangers-and...
