Modeling A Stone Wick
Any ideas or thoughts on how I could model a stone wick separating a forebay and the primary infiltration basin?
I really need to somehow show this as a broad-crested weir, that has a 40% void ratio from bottom of basin to crest.
RE: Modeling A Stone Wick
Not sure exactly what you're asking. Frankly, I doubt that storage in the voids would be significant in comparison to the overall pond storage, and any flow through the voids would be minor in comparison to the flow over the weir. If the flow is significant, you could use a special outlet device to specify flow vs depth.
Peter Smart
HydroCAD Software
www.hydrocad.net
I was asking if there was a way to model the flow through the stone before it hits the crest of the weir. But you are correct, this will be relatively minor. This was more a curiosity question.
Thank you, Peter.
