Assign part attribute to assembly files - journal
I'm using the code below to add attributes to work part. Could somebody help me modify this code to assign attributes to every part in assembly.
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports System.Windows.Forms
Module Module1
Dim theSession As Session = Session.GetSession()
Public workPart As Part = theSession.Parts.Work
Sub Main()
Dim myDialog As New Dialog1
myDialog.myPart = workPart.FullPath
myDialog.ShowDialog()
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
End Function
End Module
Public Class Dialog1
Public myPart As String
Private myAttributeTitle(2) As String
Private Sub OK_Button_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles OK_Button.Click
Me.DialogResult = System.Windows.Forms.DialogResult.OK
Try
workPart.SetAttribute(myAttributeTitle(0), TextBox1.Text)
Catch ex As Exception
MsgBox(myAttributeTitle(0) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(1), TextBox2.Text)
MsgBox(myAttributeTitle(1) & " : " & ex.Message)
End Try
Me.Close()
End Sub
Private Sub Cancel_Button_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Cancel_Button.Click
Me.DialogResult = System.Windows.Forms.DialogResult.Cancel
Me.Close()
End Sub
Private Sub Dialog1_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
Me.Text = myPart
myAttributeTitle(0) = "NAME"
myAttributeTitle(1) = "DATE"
Dim currentDate As String = Nothing
currentDate = Format(Today, "dd.MM.yyyy")
TextBox1.Text = ""
Label1.Text = myAttributeTitle(0)
TextBox2.Text = currentDate
Label2.Text = myAttributeTitle(1)
End Sub
End Class
<Global.Microsoft.VisualBasic.CompilerServices.DesignerGenerated()> _
Partial Class Dialog1
Inherits System.Windows.Forms.Form
'Form overrides dispose to clean up the component list.
<System.Diagnostics.DebuggerNonUserCode()> _
Protected Overrides Sub Dispose(ByVal disposing As Boolean)
Try
If disposing AndAlso components IsNot Nothing Then
components.Dispose()
End If
Finally
MyBase.Dispose(disposing)
End Try
End Sub
'Required by the Windows Form Designer
Private components As System.ComponentModel.IContainer
'NOTE: The following procedure is required by the Windows Form Designer
'It can be modified using the Windows Form Designer.
'Do not modify it using the code editor.
<System.Diagnostics.DebuggerStepThrough()> _
Private Sub InitializeComponent()
Me.TableLayoutPanel1 = New System.Windows.Forms.TableLayoutPanel()
Me.OK_Button = New System.Windows.Forms.Button()
Me.Cancel_Button = New System.Windows.Forms.Button()
Me.Label1 = New System.Windows.Forms.Label()
Me.TextBox1 = New System.Windows.Forms.TextBox()
Me.TextBox2 = New System.Windows.Forms.TextBox()
Me.Label2 = New System.Windows.Forms.Label()
Me.TableLayoutPanel1.SuspendLayout()
Me.SuspendLayout()
'TableLayoutPanel1
Me.TableLayoutPanel1.Anchor = CType((System.Windows.Forms.AnchorStyles.Bottom Or System.Windows.Forms.AnchorStyles.Right), System.Windows.Forms.AnchorStyles)
Me.TableLayoutPanel1.ColumnCount = 2
Me.TableLayoutPanel1.ColumnStyles.Add(New System.Windows.Forms.ColumnStyle(System.Windows.Forms.SizeType.Percent, 50.0!))
Me.TableLayoutPanel1.Controls.Add(Me.OK_Button, 0, 0)
Me.TableLayoutPanel1.Controls.Add(Me.Cancel_Button, 1, 0)
Me.TableLayoutPanel1.Location = New System.Drawing.Point(277, 122)
Me.TableLayoutPanel1.Name = "TableLayoutPanel1"
Me.TableLayoutPanel1.RowCount = 1
Me.TableLayoutPanel1.RowStyles.Add(New System.Windows.Forms.RowStyle(System.Windows.Forms.SizeType.Percent, 50.0!))
Me.TableLayoutPanel1.Size = New System.Drawing.Size(146, 29)
Me.TableLayoutPanel1.TabIndex = 0
'OK_Button
Me.OK_Button.Anchor = System.Windows.Forms.AnchorStyles.None
Me.OK_Button.Location = New System.Drawing.Point(3, 3)
Me.OK_Button.Name = "OK_Button"
Me.OK_Button.Size = New System.Drawing.Size(67, 23)
Me.OK_Button.TabIndex = 0
Me.OK_Button.Text = "OK"
'Cancel_Button
Me.Cancel_Button.Anchor = System.Windows.Forms.AnchorStyles.None
Me.Cancel_Button.DialogResult = System.Windows.Forms.DialogResult.Cancel
Me.Cancel_Button.Location = New System.Drawing.Point(76, 3)
Me.Cancel_Button.Name = "Cancel_Button"
Me.Cancel_Button.Size = New System.Drawing.Size(67, 23)
Me.Cancel_Button.TabIndex = 1
Me.Cancel_Button.Text = "Cancel"
'Label1
Me.Label1.Location = New System.Drawing.Point(9, 19)
Me.Label1.Name = "Label1"
Me.Label1.Size = New System.Drawing.Size(134, 26)
Me.Label1.TabIndex = 1
Me.Label1.Text = "Attribute:"
Me.Label1.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox1
Me.TextBox1.Location = New System.Drawing.Point(149, 23)
Me.TextBox1.Name = "TextBox1"
Me.TextBox1.Size = New System.Drawing.Size(234, 20)
Me.TextBox1.TabIndex = 2
'TextBox2
Me.TextBox2.Location = New System.Drawing.Point(149, 49)
Me.TextBox2.Name = "TextBox2"
Me.TextBox2.Size = New System.Drawing.Size(234, 20)
Me.TextBox2.TabIndex = 4
'Label2
Me.Label2.Location = New System.Drawing.Point(9, 45)
Me.Label2.Name = "Label2"
Me.Label2.Size = New System.Drawing.Size(134, 26)
Me.Label2.TabIndex = 3
Me.Label2.Text = "Attribute:"
Me.Label2.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'Dialog1
Me.AcceptButton = Me.OK_Button
Me.AutoScaleDimensions = New System.Drawing.SizeF(6.0!, 13.0!)
Me.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font
Me.CancelButton = Me.Cancel_Button
Me.ClientSize = New System.Drawing.Size(435, 163)
Me.Controls.Add(Me.TextBox2)
Me.Controls.Add(Me.Label2)
Me.Controls.Add(Me.TextBox1)
Me.Controls.Add(Me.Label1)
Me.Controls.Add(Me.TableLayoutPanel1)
Me.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedDialog
Me.MaximizeBox = False
Me.MinimizeBox = False
Me.Name = "Dialog1"
Me.ShowInTaskbar = False
Me.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent
Me.Text = "Dialog1"
Me.TableLayoutPanel1.ResumeLayout(False)
Me.ResumeLayout(False)
Me.PerformLayout()
End Sub
Friend WithEvents TableLayoutPanel1 As System.Windows.Forms.TableLayoutPanel
Friend WithEvents OK_Button As System.Windows.Forms.Button
Friend WithEvents Cancel_Button As System.Windows.Forms.Button
Friend WithEvents Label1 As System.Windows.Forms.Label
Friend WithEvents TextBox1 As System.Windows.Forms.TextBox
Friend WithEvents TextBox2 As System.Windows.Forms.TextBox
Friend WithEvents Label2 As System.Windows.Forms.Label
End Class
RE: Assign part attribute to assembly files - journal
What version of NX you are on? I guess you can do it OOTB starting NX8.5 (sorry may be NX8 also but my memory is a bit weak).
Select all the components in the ANT and specify the attributes in the Properties tab.
Best Regards
Kapil Sharma
Could you please search some old posts on this forum. I think I have seen similar query last year.And there was a vb code furnished for the same.
Kapil
CODE
Option Strict Off Imports System Imports NXOpen Imports NXOpen.UF Imports NXOpen.UI Imports NXOpen.Utilities Imports NXOpen.Assemblies Module assign_attributes_to_component_parts Public s As Session = Session.GetSession() Public ufs As UFSession = UFSession.GetUFSession() Public lw As ListingWindow = s.ListingWindow Sub Main() Dim dispPart As Part = s.Parts.Display Try Dim part1 As Part part1 = s.Parts.Work 'LabelPart(part1) Dim c As ComponentAssembly = part1.ComponentAssembly Walk(c.RootComponent, 0) Catch e As Exception s.ListingWindow.WriteLine("Failed: " & e.ToString) End Try End Sub Sub Walk(ByVal c As Component, ByVal level As Integer) Dim children As Component() = c.GetChildren() Dim child As Component Dim prototype As Part If TypeOf c.Prototype Is Part Then prototype = CType(c.Prototype, Part) Dim fileName As String = "" Dim value1 As String = "" Dim title1 As String = "NAME" value1 = InputBox("NAME: ", value1) prototype.SetAttribute(title1, value1) For Each child In children Walk(child, level + 1) Next End If End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer Return Session.LibraryUnloadOption.Immediately End Function End ModuleOnce again I would like to ask for your help in editing the code I posted earlier. I'm not skilled enough to do it myself.
www.nxjournaling.com
