Inverter base AC Power and Turbine based
what are the limitations of inverter based AC Power towards load change as compared to AC Power from rotating machine (turbines )?
RE: Inverter base AC Power and Turbine based
At least a solar panel will give you predictable periods of no power, followed by possible power each day as "some" power might be produced. Depending on clouds, fog, day-of-year solar elevation changes, and local interferences like trees, buildings, and hills.
Bill
"Why not the best?"
Jimmy Carter
If an inverter is overloaded, it will likely just shut down. A rotating machine will slow down, but would have more stored energy available to get you through a motor start.
The inverter can go from 0% to 100% in sub-cycle time frames, but as David said, it is only going to output what it is rated for. Inverters have limited overload capability.
