Acceleration_NX9
Acceleration_NX9
Acceleration_NX9
I need to simulate stress during manipulation with some parts. So I have to apply an acceleration of 5G to the whole assembly in the certain direction.
In the acceleration dialog box I set the option Whole Model- Magnitude and Direction.
It is mandatory to set scaling in the acceleration dialog box. But I don't want the acceleration would vary through model. What should I set there? (Or have I understood scaling wrong?)
Another problme is that I don't have any geometry. I have received only mesh of the components and some mass points, which are connected to the 3D mesh by rigid links. So I can't select body/faces....
Thank you for your help,
HonzaS
