Bi-directional pump via reversible rotary input
Do these exist? Basically I'm looking for a pump that will flow one way when you spin the shaft CW and another when you spin it CCW, at similar pressure both directions. This is for a hydraulic actuator application, 200 psi max. (spin the pump CW-- actuator extends, spin pump CCW-- cylinder retracts).
RE: Bi-directional pump via reversible rotary input
Gear pumps.
A hydraulic relay will do this as well switching inlet and outlet and allows you to use any type of pump...
If you need something you can spin by hand, try googling for a "helm pump" (or looking for one at somewhere like www.willsridley.com) - these do what you're asking for, and come with integrated reservoir and a valve package to prevent the pump motoring in response to a load on the actuators.
A.
Parker makes DC motor/pump packages which are bi-directional. Some recreational vehicles use this to power hydraulic systems with extend and retract cylinders.
Ted
