New Global shaping function since NX8.5
RE: New Global shaping function since NX8.5
Didier,
IF you make the control surface large enough in BOTH 7.5 and 8.5, can you find any difference between the resulting bodies ?
The simple test i made on the model you supplied gave me results which i think is identical.
If the result is identical, the need for the 7.5 code isn't that critical?
Tomas
simple solution in Nx8.5 and above,
make the base and control face:
1. larger than the model to deform in this case
2. make them equal size / there is something like scaling control
hope it helps
I know that it's better to have the surface larger than the model and this works fine with NX8.5. the result is the same
But I have opened this call for one customer who use this method for many years. In NX7.5, with a smaller surface, the global shaping is able to interpolate the surface but not in NX8.5
Didier Psaltopoulos
http://www.psi-cad.com
I suspect that to some users this 'interpolation' was seen as being undesirable.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
