R factor for two different structural systems
I'm doing the structural evaluation of a 3-story building that has in one direction only confined masonry. For earthquake loads the building doesn't comply with any requirement and we are adding concrete shear walls. During the evaluation I used an R factor of 3 but now that I have added new concrete shear walls I wonder if I can increase the R factor to 6? or should I keep it as R=3?
I would appreciate if you can give me your comments.
RE: R factor for two different structural systems
Mike McCann
MMC Engineering
