304L SS Design Temperature
I have a vessel that has to be designed for a cold temperature
lower than the -320F limit (-350F). The vesel is small, 36" diameter,
vacuum design pressure. Is there guidance in the ASME Code
to qualify this material when it gets that cold?
RE: 304L SS Design Temperature
Yes, refer to ASME VIII Div 1 and ASME II part D
