Alphabetic order parts in Reuse Library
as you can see in the image attached, the parts doesn't follow the alphabetic order.
Exist an option in the customer default (I didn't find) that put the KE parts in alphabetic order ?
Thank you...
Using NX 8 and TC9.1
RE: Alphabetic order parts in Reuse Library
switch the preview style to table and click the object coluumn.
hope it helps
Sorry,
I post the problem after switch every preview, but the table preview, doesn't use the preview image of the family master, then the user can't understand only by the name, but with the preview.
Thank you...
How do you list Reuse Library members by part attribute
Symptom
How do you list Reuse Library members by part attribute.
Hardware/Software Configuration
All supported platforms
Unigraphics NX 8.5 and higher
Solution
In NX8.5, you can display Reuse Library using user defined part attribute by
setting it in customer defaults:
Customer Defaults --> Gateway --> Reuse Library --> General --> Descriptive
Name --> Specified Attributes, then type your attributes in the box:
<MyAttribute1>-<MyAttribute2>
Note: This setting is available in NX8 but it only works in NX8.5
Thank you...
