Thermocouple Identification
I would like to source a thermocouple with the following rating, or as close as possible, in a strip type configuration. Could anyone identify this style of thermocouple? It is a plastic rectangle, 8.67mm X 25.45mm X 1mm thickness. It has two solder pads. This would be used in temp feedback in a ceramic glass induction cooktop. The spec below was originally a package style 35 axial component but a strip type package would be more robust for the application.
PACKAGE STYLE:?
B VALUE: B = 4300K <MOD-PM> 1%
(CALCULATED FROM RESISTANCE AT 100°C AND 200°C)
RESISTANCE: R = 14.2K Ω <MOD-PM> 2%
(MEASURE 75<MOD-DEG>C IN OIL SPOT)
OPERATING TEMP. RANGE: -20°C ~ 200°C
Thanks!
PACKAGE STYLE:?
Thanks!
RE: Thermocouple Identification
TTFN
