Aircraft integral fuel tank
My company is designing a new aircraft trainer whith an integral fuel tank.
The aircraft is completely metallic and I have to give all the necessary information to give a tank which is lightning proof.
I am not sure about what is truly necessary to avoid sparking inside the tank in case of lightning attachment.
(Sealing of bolts, sealing of all the tank internal surface.......and so on.
Is there anybody that could help me.
Ciao e grazie
Ciao e grazie
RE: Aircraft integral fuel tank
Nigel Waterhouse
n_a_waterhouse@hotmail.com
A licensed aircraft mechanic and graduate engineer. Attended university in England and graduated in 1996. Currenty,living in British Columbia,Canada, working as a design engineer responsible for aircraft mods and STC's.
On military aircraft the normal procedure is to seal the whole join with fuel proof polysulphide sealant ensuring coverage of the rivet heads, the edges of the strip and the seam on the inner surface of the tank.
This isn't a bad thing for fuel sealing either.
It´s the best I found about lightning protection
F.A.Fisher/J.A.Plumer
Lightning Protection of Aircraft
copyright 1990 Lightning Technology Inc.
1. Go to: http://www2.airweb.faa.gov/REGULATORY_AND_GUIDANCE_LIBRARY/RGADVISORYCIRCULAR.NSF/MAINFRAMENETSCAPE4X?OpenFrameSet
down-load the following ACs:
AC 20-53 Protection of Airplane Fuel Systems Against Fuel Vapor Ignition Due to Lightning.
AC 20-136 Protection of Electrical and electronic Systems Against the Indirect Affects of Lightning.
The following can be down loaded at various sites [points to much good data]:
MIL-STD-464 Electromagnetic Environmental Effects Requirements for Systems
Regards, Wil Taylor
