Nx 7.5 Body Extracting
I was wondering if you could help me. I am relatively new to nx and have read through a load of threads to try and get advice. I am trying to produce a part and create a range of stage operation drawings however I am having issues when extracting the body. I have produced the part fully and I am now trying to create extractions but when I do, it creates them all based on the first extrusion. I think it is something to do with the dependencies. I want to put the bodies into layers so that each layer shows each step of manufacture and then I can go onto produce drawings for each of these.
I know this may not be clear but hope you can help. Any advice would be appreciated
RE: Nx 7.5 Body Extracting
Please check the TIMESTAMP option while creating the extraction. You can keep it ON for your staged data. Also could you please post an image of the same (Part Navigator). However (i may be wrong also) depending on the sort of product you are working upon...you might have considered wave linking to have different staged part versions of the same. Depending on the Layers for segregating multiple solids may be a tricky issue afterall.
Thanks and Best Regards
Kapil Sharma
Khimani Mohiki
Design Engineer - Aston Martin
NX8.5
An extraction of the highlighted object already exists in this part, due to an earlier operation. Do you really want to create another?
Khimani Mohiki
NX8.5
This is more of a warning rather than an error message. It helps prevent the user from unintentionally creating copies of features, making a mess of the feature tree, and confusing others that work on the part. In your case, the extracted bodies are for documentation purposes only, so yes: you DO want to create another.
www.nxjournaling.com
I would still prefer to have staged data in different parts using wave links. You might have noticed the same behavior in some other modules also.(progressive die wizard for ex)
This way you will have a better control over the staged part updates (what if you want to share a staged data with some other user? I guess you won't like to hand him over the entire part)
Best Regards
Kapil Sharma
Thanks for the help
