Patran elemnt property assigning problem
I am using Patran for 2D meshing. I found a problem regarding to assgning properties. I had created properties and also add elements in side property. Now If I checcked these properties using Show>Thickness I couldn´t get this property. All elements have been inside this property but i can´t see in thickness plot.
If I create group without elemet property, all these element have been appper in this group. I tried to create new property and assigning all element again in this property but it is not working.
Can anyone please help me out on this??????
Thanks in advance......
RE: Patran elemnt property assigning problem
If you export a bdf file, is there a thickness value for the PSHELL card?
As it is not assigning property...all these elements been not shown in bdf file.....
are the elm associated to any geometry? try adding a geometric body to the property if this is the case
