HI-LITE PINS CHART
HI-LITE PINS CHART
Hello, I have an issue, this is my first time replacing HI-LITES, I am working on a B737-500, the part number as a nominal is HST116-6-5 and also HST106-6-5, that is the fastener on the aircraft, now, that what I am removing, but I cannot find the first oversize for those part numbers, I check several web sites, but nothing talk about my part numbers, any help?... thanks
RE: HI-LITE PINS CHART
Check out this thread: thread2-65144: Boeing Fasteners
Citing:
"The Boeing D-590 Parts Standards manual lists, in the individual listing for each standard, the manufacturer's part number for each of their products that are qualified to that standard (the hiloks, that is; this type of coverage is somehwat spotty for other types of standards, esp. the older ones).
What's even more aggravating is Boeing's use of fastener codes. Their repairs contain their own (usually) three-character fastener codes, which you then have to look up to cross to the BACB30 part numbers, which you then have to look up in another table to cross to the HL part numbers.
At least oversize fasteners are easy with Boeing part numbers: add an 'X' to the end of the complete part number for 1/64" over nominal; add a 'Y' to the end for 1/32" over; and add a 'Z' to the end for 3/64" over (though the 'Z's are pretty rare, and expensive when you can find them)."
Quando Omni Flunkus Moritati
"On the human scale, the laws of Newtonian Physics are non-negotiable"
