Maximum opening size on a blind flange; ASME BPV
Where can I find out what is the maximum opening size I can make on a 'regular' blind flange (say, 3"-300#) and on a 'hubbed' blind flange?
RE: Maximum opening size on a blind flange; ASME BPV
Gerald
Of course this will make a big hole in a 3" flange, but if you consider that the blind thickness is the same as the thickness of the flange...
prex
http://www.xcalcs.com
Online tools for structural design
http://www.hsbct.com/PressPtsNewsletrs/ppjune99.pdf
Tom
