one direction unrestrained move bolted connection
Hi
For elevated walkway steel structure supporting column top connection. I want to have unrestrained one direction move bolted connection to allow for thermal and deflection caused expansion and contraction to act as expansion joint.
Using base plate with slot bolt connection should suit my need?
Is there some arrangements to allow for directional move? As tightening the bolts will cause such movement to still cause friction with washer and base plate.
RE: one direction unrestrained move bolted connection
Look into the slide pads. Basically fixed on one end of your bridge and 'sliding' on the other.
Actually I mean the walkway is being supported by steel column in which I wanted to allow for one direction movement.
My qpproach is that I wanted to prevent "if possible" the tear of column top base plate in contact with the bolts the same fore thd bolts.
The supported spans from both sides of ghis column are 22 meters and 15 in the other side.
Do you agree on allowing for directional movement or not needed?
Any reference standard in this topic is highly appreciated too.
Best regards
See the central column in attached picture.
Similar case im talking about. But 2 columns supporting the concerened section.
Especially because lateral on the walkway is not going to be such a problem if the walkway is essentially a continuous element going across the central column.
Columns tilt or deflect in one direction but are fairly rigid in lateral direction. The angle of "tilt" is very small because of the ratio of longitudinal thermal movement to height of column.
I would probably try to pin the column top and bottom laterally and fix it in-line.
Michael.
"Science adjusts its views based on what's observed. Faith is the denial of observation so that belief can be preserved." ~ Tim Minchin
Any reference in regards the need/or not to have the expansion joint? Especially In terms of thermal expansion/contraction.
In terms of deflection it is limited to 10 mm.
The elevated walkway will connect between 2 existing buildings; that is why I have placed in both ends additional columns as original design of both buildings didn't consider that addition of 200 kN. Although it may pass but didn't want to risk.
How wide and how tall will this walkway be?
Height from ground is 5 meter. Length 45.
Exposure to wind is limited.
Michael.
